where is written " DB .1 mm,point logic " I am not clear.
Would explain me anyone this line?
100:L PR[99:reserved] 2000mm/sec CNT100 Offset,PR[91:reserved] DB .1mm,POINT_LOGIC ;
1: R[50:Contapassi RIP]=1010
I would be grateful.
DB = distance before
So, .1 mm before the point is reached it will execute the point logic. The point logic is setting R[50]
Sent from my SM-G930V using Tapatalk
thanks a lot.
#HawkME
Hi
Now that you know what it means you also have to understand that you are approaching the point with a CNT100 at 2000m/s so .1mm could mean absolutely nothing
Strangely enough, it does differ for some situations.
When you have a CNT 100, you cut a corner. I expected to change a given R at the half of the cutted corner. However, it turned out it was at the beginning of the cutting corner.
When I added something like DB, DA or TB, TA with a very small value, the R was changed more accurate near the half of the cutted corner.
