Comau NJ60-2.2 for Milling
  • Hi,
    This Comau Robot Milling project has been haunting me for quite a while, the issue is when 1st attempt milling a 3D head sculpture the front, back and Z direction do not align this is been solved (TCP wasn't correctly done and Uframe) once this solved the next problem is there's always a 8mm excess of poly between the front part and rear part. By solving this we adjust the tool length by 4mm at -z direction and my question is why is this happening?
    By the way CAM software used is Sprut'm
    Coamu controller CG5.
    thanks,
    Edited once, last by c2c2 ().
  • Sculpting projects I know of use a turntable and the robot has absolute accuracy option.
    I would otherwise consider an 8 mm error an artifact of some wrong configuration.
    Sent from my iPhone using Tapatalk
  • Did you use a Comau provided mastering tool? If using a mastering tool (and provided that robot calibration is perfect!) you have a procedure described on Control Unit Use manual to properly calculate your actual tool.
