I have a program with 300+ positions. NOT Position registers. Is there any easy way to changing the user frame for all points besides stepping through each point and manually reteaching the point with the new User frame? Thanks in advance.
What happened is i have two similar parts. I copied one renamed the program and made all my adjustments stepping through the whole program. Half way through i realized i didn't set up a user frame for that part. So when i was done, i set it up the user frame but now have to go back and reteach all of the points to the correct User frame. I will try saving it as LS file and changing that way and see how it goes.
EDIT: There is a option under utility that can change one frame to another for an entire program but the part is slightly off from the first so all my points and are off because they were taught under the first part User frame. Think i just screwed myself in a corner. looks like i have to step through the whole program and change it one by one....
