hey,
I Need to connect 3 robots and one positioner ..is this possiable??
if yes, is it with a mechatrolink or how..??
how to make them i rum in synchro motion..??
hey,
Yes sir!
You can use one controller as master and others are slaves.
For programming use P-start and P- wait option.
regards
Possible, but if they are working as single robots (3 pendants) you'll need to do some connections and setup to make them work whit one pendant.
if you already have them working with one pendant create your sequence for the job With this control group R1R2R3:S1 or create one program for every robot(R1)(R2)(R3) and positioner (S1) then create your sequence in a Master program.
you might want use synchronizing for the robots to avoid collisions
