Is it possible to change default target naming in RobotStudio?
Currently, target is created as "Target_number". I want to change the name so that I don't rename afterwards.
Thank you.
Thank you.
If I understand correct...
You can right click the target-- goto rename targets -- you then get to pick a 'prefix', 'increment' and 'suffix'.
By your question, I assume you are creating simulation programs. Is this the case?
