Looking for what file i can take from my MD back up to edit it all digital I/O names off line in a txt editor and the the load into may robots so all my I/O in all robots is the same
edit I/O file
cmw -
September 13, 2017 at 8:35 PM -
All of that info is stored in DIOCFGSV.IO which is a binary file. You wont be able to easily edit that.
I usually write a karel program with all of the I/O comments pulled in from a spread sheet that I use for managing all of my projects.
got to be a better way I can open the .DG file and edit it in a txt editor but can not re load the DG file
If the I/O is exactly the same, you could use the web browser to quickly add comments to one robot. Then you could copy DIOCFGSV.IO to the rest of your robots.
Looking for what file i can take from my MD back up to edit it all digital I/O names off line in a txt editor and the the load into may robots so all my I/O in all robots is the samecmw, if You want only edit the I/O names, You can try Comment Tool, from our forum colleague linuxsand
