Hey guys, last month my IRB1400 with S4, started to stop the auto cycle every 3-4 cycles with "20006 Auto stop" failure. There is no rule when he stops - once he stops right after cycle starts, once he ends cycle and then stops.. any suggestions what may be wrong or what should I check?
IRB 1400 S4 - 20006 Auto stop
karubot -
August 7, 2017 at 1:59 PM -
The #1 cause I've found over the years has been the gate switch is intermittently opening due to bad fit, wobbly fence, loose/broken wire, and/or dirty switch contacts.
Have also found the jumpers on XT3 crimped on the insulation instead of the wire due to the deep pockets on the XT3 terminal block.
As above, look for an external wiring fault, try shaking the wiring/containment to gate switch, E.stop boxes etc. and see if the fault appears.
Solved it - the problem was that anti-splatter spray (it is a welding station with IRBP positioner) was causing interference in safety beams...
Thanks for letting us know the outcome
