Hi wondering if any one can help me out
I had to replace all the batteries on a ABB M2000 controller including the 3v battery on the CPU board and UPS system now I'm trying to do could start put continues saying please wait on tech pendent waited 3000 seconds not much luck
Total memory loss
Pcavan -
August 5, 2017 at 6:39 AM -
Might be a corrupt image file. There's a procedure around here (somewhere) to delete that file (which the machine will rebuild). It uses a serial cable and HyperTerm. If you have network access to the machine, you might be able to remove it that way.
Added PDF procedure 'S4C+ HyperTerminal Initialization' to ABB Manual, Software & Tools section.
Thanks for every ones help I had the replace the hard drive as well that provent it from booting I used a Sata / IDE to USB drive adapter to access the hard drive removed the old system then reinstall had issues with not enough space on drive for 2 systems
At least next time when changing the computer batteries leave the controller on during the change if need to do a shut down do as a control shut to save the memory to hard drive sadly in my case the hard drive stopped working at same time
