Hi. I want to edit some lines in config.dat and after i press save it stays like i saved it, but after i restart the robot, the changes are no longer there.
Can you, please, tell me what the problem is? Thank you!
Hi. Are you using a SmartPAD to edit? If yes try to deselect or deactivate Submit Interpreter on the pad. After edit you can activate the Submit Interpreter back.
Yeah i`m using one. I`ll try it and let you know if it works. Thank you!
