Good night sir...I want to ask if you want to change the diameter of welding wire robot otc daihen how sir?
Sent from my iPhone using Tapatalk
you must create e new arc-caratteristic with correct diameter
costant setting----arc weld application......and search the menu for register new caratteristic
you must create e new arc-caratteristic with correct diametercostant setting----arc weld application......and search the menu for register new caratteristic
Ohhh this is yes sir ,,,,
After the monitor on the robot set ,, for which in his welding machine it will automatically follow the settings on the monitor what needs to be in the setting itself sir ?? Please help
After register the new arc-caratteristic, the powersource change the led only when robot read the AS istruction
Yes sir, thanks you very much sir
Sent from my vivo 1718 using Tapatalk
