I cant seem to figure this one out. I want to monitor two DI no matter where i am at in my program to which then resets two different registers. I have tried a monitoring COND but it works as a one shot ( resets my registers but then if i try it again it wont reset them over again until it hits that point in the program where i have the MONITOR COND). So i want it to constantly loop in the background and reset the registers every time the robot receives either of those DI. Thanks in advance.
BG logic
Kyle0588 -
July 13, 2017 at 10:28 PM -
It should be something as simple as this:
This would constantly reset it as long as the signal was on. If you wanted to do something like a one shot on the rising edge of the signal, you would have to get fancier. Those are covered in the sticky at the top of the forum.
Instead of using the instruction MONITOR / MONITOR END, you can use the SYSTEM Monitor, which basically run the COND program in background but it does not depend on the instruction MONITOR in a program.
