Can I access a usb drive plugged into the teach pendent using ftp from a computer?
Can you access a usb drive plugged into the teach pendent?
machida -
June 29, 2017 at 10:43 PM -
not 100% sure if ut1 is accessible, but give it a try. Just make sure there is a stick in the TP's USB port and type ut1:\ as the target folder for your FTP client.
Not sure why you would want to do that?
If you are using an ftp server, why would you want to use the USB stick?
To save memory on the md device. If possible, it would be a larger and cheaper storage option.
