During power on/off robot shutdown with cold boot. We check the battery connection,voltage and on/off selection but we didn't find the solution please help me to resolve the issue.
Cold start
MADHU.H.B -
May 8, 2017 at 12:32 PM -
what IS your issue?
a) boot type? boot type is selectable from menu. to make a permanent selection user registry file in C:\KRC\UTIL\REGUTIL
b) controller shuts down instantly when disconnect is turned off? you check battery how? what is the voltage? did you check fuses?...
what is the history of the unit? was it working fine and one day just stopped or it was powered off for days?
how to cold start a VKRC 1 controller ?
Thread
READ FIRST...
how to post correctly:
1. be a good citizen and follow common sense. this includes no sharing or asking for copyrighted material. such posts will get you banned (because we don't want Kuka legal team stepping in and request ban on all manuals). an example of something that will get you in trouble is any material from Kuka College.
1.5 make SURE to post in the right forum section (manuals in manuals section, IIWA and Sunrise topics in IIWA section). see attached example for IIWA... sigh..
Please…panic modeJune 5, 2016 at 4:30 PM -
I Read your "Read First " Several time...
its not a answer for every question ...
my question is to how to cold start a Vkrc 1 controller ?
correct, and it does not aim to answer all questions of the universe.
but it does tell how to ask for help and you did not state what version, what did you try etc.
talking about version, you only stated "VKRC1". but that is hardware. to shut it down simply turn off the main disconnect. problem solved.
but if that does not work, you need to be more specific. and i am pretty sure that type of boot is a software setting but you did not mention software version.
btw. specifying robot arm model would be equally useless here because that is also a piece of hardware.
the way question is asked will be major factor in type of help received.
not sure if your VSS will have it but KSS normally included *.REG files for this.
