Someone shutdown the main and we lost the display on our Pendant for a R-222ic/165F controller R-30ib
What is the procedure to restore the program
check the fuse, it may have blown
Someone shutdown the main and we lost the display on our Pendant for a R-222ic/165F controller R-30ibWhat is the procedure to restore the program
No offence but...
Dose the fan work?
Can you hear anything?
When you say main, Is it the disconnect on the robot controller? or a main in some other panel, or a main on a breaker box on the wall?
GAF1953 you have 5 threads going with the same subject. Is this the same problem as the other threads?
