Hi
It is first time i will work with Kawasaki robots. before i worked with Yaskawa and Mitsubishi. i want to give backup from Data and Error logs. how can i do?
are there any site for give manuals for work with robot same as Yaskawa?
Hi
I attached you the save commands. Please have a look over the 90209-1022DEC_E-Series-AS-Language_Reference_Manual.
You need to contact the local Kawasaki distributor for the manuals.
Those commands can be used from the terminal. There is another posibility to save the backup using USB FAT32 memory stick.
Thank you.
do i need special software in my PC when i use this instruction?
if it is possible please tell me method of save and load on USB or CF via Teach Pendant.
