I bought a 128MB memory, I recorded the program for the NX100 controller provided by YASKAWA, but it is as if the teach pendant does not read the memory... Any recommendation?
CF Cards Capacity
TSGIR -
March 13, 2017 at 6:52 AM -
Thread is Resolved
when you go to FD/CF, make sure you choose DEVICE first and set the device to Compact Flash. Then try resaving the job.
If the controller has older firmware (ie. low to mid 3'S) then you may need to get a smaller flashcard, such as 32MB. Check the firmware by going SYSTEM INFO - VERSION and look at the version of firmware in the first line.
My robot does not get past the MOTOMAN startup image. I wish I could send images or the document of everything that has happened to me =(
Is it correct to format the CF in fat 16, fat32, nfts format? I guess the correct one is fat16.
No. Since you are having multiple issues with your robot, it is best to contact your local Yaskawa office directly to determine why you are having problems with boot up, and for them to format your CF card properly.
Thank you, I was able to solve it.
