With Robot Studio how do I enable the Controller -> Access set of commands such as Request Write Access & Authenticate. I can't understand why these are disabled
RobotStudio Authenticate
gmorris59 -
February 10, 2017 at 4:32 PM -
Are you connected to a controller? You can access your modules and routines on the controller but you can not change anything until you request write access. You will then confirm the access on the teach pendant and you will be able to edit your programs on the controller thru robotstudio online tab
Sent from my iPhone using Tapatalk
Probaly you have UAS settings active? If that is the case, then the default user might not be able to request write access.
Jeroen
Running with the virtual controller so probably UAS settings are active as logged in with Default user. How can I change this?
