What character settings of the program name of robo fanuc?
How many characters
Which ones can not?
And the comments?
thanks
How many characters
Which ones can not?
And the comments?
thanks
It may matter which robot controller you are working with.
The total length of the program name cannot eight
characters. You can use words, upper case letters, and lower case
letters to form the program name. Give the program a unique name that
indicates the purpose of the program.
You cannot use the asterisk * symbol.
This is for RJ-2's, not sure if it holds true over all controllers.
Bruno_GRU
I'm using a program called MAJOR_FLAP_ANGLE right now, that is 16 charcters
Just go to the pendant and create a program. Star naming it ABCD...... until you can not write anymore
As far as the characters, do the same procedure, write A!@#$%^&*
thanks guys,
You helped me a lot.
that's all OK
the R-30iB should handle program names with 36 characters IIRC.
