Hello Robot-Forumers,
I have both an EMT and a SEMD. When Trying to check master with a SEMD the results were 0 degrees and 0 motor counts different. It almost looked like it wasn't working right. The EMT gave .003 degrees and a couple hundred motor counts as expected for a custom axis arm (not machined by KUKA).
Is there a bit to be set in configuration to use the SEMD tool instead of the EMT for mastering?
Thank you, Del
