NX 100/SSA 2000/ TILT-ROTATE TABLE. While programming in teach mode is there a way to override the speed limit function of the rotate axis so I can get the proper size welds on my parts. VJ of this axis needs to be around 30%. Works fine in play but it is a challenge to program in teach. Also rotate axis reaches its pulse limit after 1 revolution. Can I open this window to possibly 3 revolutions.
Thanks In advance.
Mike
speed override
mike mitchell -
December 15, 2016 at 1:09 PM -
Hi Mike,
Sorry no you can't override the teach speed limit. This is a safety thing.
With the tilt rotate tables, the rotate is normally set to 360 deg rotation. You will have to call Motoman in to get the setup of the rotation axis to a bigger number to suit your needs, you may need the endless rotation function.
Thank You
