Hi There,
Does anyone know who to move/jog to robot in specified distance incremental like other robot i.e. ABB.
there is only three speeds. FAST MED and Slow. I want to used 6mm or something custom entry.
Any help would be much appreciated.
Hi There,
Which controller?
Sent from my iPhone using Tapatalk
There is also inching speed. This moves the robot 1 pulse if in joint or 0.3mm if in rectangular, tool or user coordinate system.
You could write a job that has an IMOV instruction in it. Pick an unused P-Variable, set it to, for example (6, 0, 0, 0, 0, 0) to move 6mm in X only. Then Interlock/Test Start the job. The move instruction would look something like this:
IMOV P000
where P000 is the variable you created. Every time you run the job, the robot will move linearly +6mm in X.
You could get even more creative with this by using GETE/SETE instructions to load the values you want into the P-Var, and map I/O to get the values from a PLC or some other external source, something like the following:
SETE P000 (1) D000
SETE P000 (2) 0
SETE P000 (3) 0
SETE P000 (4) 0
SETE P000 (5) 0
SETE P000 (6) 0
IMOV P000
where D000 is expressed in microns (or mm * 1000), and D000 can be copied over (via a DIN IG(x) instruction) from mapped I/O if you want to be able to set this value from a PLC or HMI, etc.
Also, the example I show here is for linear coordinates (world, tool, or user). I don't think IMOV is valid for pulse type position variables, but I could be wrong about that? If you need to incrementally move in pulse positions, you would need to do a GETS $PX000 to get the current position in pulse, then do some GETE/math/SETE instructions to add or subtract individual joint values, then do a MOV instruction to the modified position.
Scott
