Can you help me with identification my motherboard of KRC1 ?
I have KR150 with KRC1, made 1999.
You see photo.
Thank you for support.
Sorry for my English
You see photo.
Look at the edges of mobo for SOYO something... (flashlight needed)
Its probably SOYO SY-71ZB
I didn´t found name on motherboard anywhere.
I don´t think it's SOYO SY-71ZB, becase I have on my mobo is six slots on RAM memory. Four are white and two are black.
you should show one picture with entire motherboard, also if this is indeed original kuka part, it will have small white sticker with article, serial and version number. take a picture of it too...
This is photo entire motherboard.
It´s original parts from KUKA.
And this is photo of version system.
Can you help me with indentification ?
Thank you.
Shuttle HOT-579
Kuka article number 00-101-699
Version: 2
Serial number: 23003
Thank you very much !!
And I'm looking manual for this motherboard now.
I want to connect PS2 mouse, but I can not find anywhere big image motherboard.
Because I don´t know which is the pin 1.
why would you care about pin1 when pins 3 and 4 are easily determined with a multimeter?
btw, it is industrial standard to mark pin1 by dot or similar on silkscreen or to make solder pad different shape (rectangular)
Good idea determined with a multimeter. Thank you very much !
I don´t want to create new topic, but I would ask this:
I want to get out of the program KSS to the Windows Start menu, but you can not do this.
Does not work shortcut CTRL + ESC.
I have connect keyboard on PS2, but no reaction for this shotcut.
Keyboard is normally operates.
Can you help me ?
Thank you.
Do CTRL + ESC on teach pendant (in expert mode)
PS/2 devices do not support hot-plugging and must be connected before power is applied.
since you state that keyboard is working, you are past this hurdle.
HMI intercepts and prevents you from accessing start menu via CTRL+ESC - unless you login as Expert.
Can you help me how I can login as expert when my system starting ?
I see in thi topic, that I must use some KEY FILE, but how to do it ?
https://www.robot-forum.com/robotforum/kuk…86352/#msg86352
Sorry, I´am begginer user in KUKA robots.
Thank you very much...
I put new HDD to my KRC1, but HDD not view when system starting.
I want install system on new HDD.
I have on this disc two section, format on FAT16 (2GB + 2GB).
I looked into the BIOS, but don´t see new disc.
Into KRC1:
- Master is new HDD
- Slave is CD-ROM
Old disc, which is ready is MAXTOR 91024D4 - Capacity 10 GB (2x section 2GB )
New disc whitch isn´t ready is SEAGATE ST3802110A - Capacity 80 GB (I have create new 2x section 2GB, format FAT16 )
Can you help me what is wrong ?
Thank you.
Most likely the size of new HDD is something that this ancient BIOS can not detect.
To check unplug CDROM and try to see if BIOS recognize hard drive alone (jumper on CS (cable select) or Master)
Good, thank you.
I set jumper master and Limit drive cap. to 32 GB and disk is view.
I tried to copy all data from old disc to new dics, but Win not running.
I find boot file on my disc. I know it probably will not work but seeking a solution, if I let it go with the new disc.
