Hello all,
As the title says, I want to copy the application and template data from an old project to a new one. It seems weird that it would be impossible, as I can copy files and all, but I cannot figure out how to do it and couldn't find anything in the documentation.
Copying all by hand would be a bit frustrating
copy Application data and Template data between projects
napol1 -
October 28, 2016 at 2:44 PM -
What kind of project? Sunrise? WorkVisual? Something else? And just what "application data" and "templates" are you referring to, specifically?
Hello all,
Copying all by hand would be a bit frustratingJust copy (or drag and drop) the "RoboticsAPI.data.xml" file from your old "/src" folder to the new one.
Just be cautious to:
- Create a backup of your old "RoboticsAPI.data.xml", in case the new one raises issues
- Don't use "RoboticsAPI.data.xml" files created by old versions of sunrise (1.7 or 1.9 on 1.11)
- But, be sure you're using it on the same robot that you used to create it in the first project, otherwise you might cause program crashes.
- re-teach tools loadsp.s. You should precise the type of robot on title to get more people involved in answering.
That was helpful ! And easier than copying the numbers one by one -
Yeah, it is
