Hi all,
Is there a System Variable that holds the comments (names) associated with UT Toolframes?
It must be a string value. Thanks in advance.
Hi all,
Any takers?
Look for a post by Nation on this thread. Looks like it requires Karel.
You don't need karel, its just a .cf file.
Interesting... any other useful things that can be done with .cf files?
Are the the same as the .cm files in the stickie?
As far as I know, you don't need any special options.
.cf files are just KCL commands. I mainly use them when setting up new robots to change a bunch of variables.
.cm files are their bigger brother, but the syntax is not well known, but is discussed a bit in the sticky thread.
Outstanding! Just what I needed. Thank you all!
And I'm with HawkME on, "Anything else interesting we can do with this?"
