MPL160 robot not moving properly
  • Silverstamp
  • September 28, 2016 at 4:40 PM
  • Silverstamp
    95
    Hello everyone! :help:
    I've this MPL160 palletizing robot that had a L axis replaced. After this was done the robot moves in a non linear way.. Let me explain; if you record a P variable point using a User Frame reference, then you for instance modifiy the Z coordinate lets say 300mm above, and you press FWD to carry the robot that new position, the robot moves but if you measure the distance travelled you will find its about 295 (minus 5mm). If you now insert 700mm in Z, without recording the previous 300mm point, and FWD the robot to that point, then mesaure again you'll find its about 690 (minus 10mm), and so on. It's like there is a proportional factor of 0,95 that applies to the movement. I hasn't made a X or Y measurement but I guess it could behave similarly.
    Could an error in the TCP calibration make such error?
    Thanks in advance...
    Franco.
  • roboprof
    24
    473
    • September 28, 2016 at 6:39 PM
    Is it possible that the calibration of the L axis is off? If mechanical 0 for L axis is wrong, it will skew all your other coordinate systems like RECT, TOOL and USER.... something to check....
  • Silverstamp
    95
    • September 28, 2016 at 7:16 PM
    Quote from roboprof
    What exactly do you mean with calibration off?
  • roboprof
    24
    473
    • September 28, 2016 at 9:53 PM
    When they change out the L axis motor or speed reducer, they need to recalibrate or remaster the axis (redefine the mechanical home for that axis - define the 0 position). If they lined up the axis incorrectly before recalibrating, that could cause the issue.
  • Silverstamp
    95
    • September 30, 2016 at 1:55 AM
    Quote from roboprof
    The red arrows where missaligned when in work home position. After doing a good visual alignment and setting the new pulse data to the L axis the measurements did a great improvement.
    Many thanks roboprof!!
