Hello
I have robot motoman NX100-SRB30F from Japan. It is japan language. How to change It to English language.
Thanks you.
NX100-SRB30F language
Harryusjp -
September 7, 2016 at 2:57 AM -
You can try the following.
Power up into Maintenance mode by holding down the MAIN MENU key while turning the power on.
Select SYSTEM menu
Select INITIALIZE
Choose your language.You may have to be in Management mode to do this changes.
I am using the DX200 maintenance manual for the information, but I am sure it will apply to the DX100 as well.
Regards
if it has bilingual language press shift+area. if you are lucky the 2nd language is english
Thanks for your reply.
I do not see main Manu or shift+area. Please see this teaching pandent. I never see it. -
this is not the stabdard nx100 PP. what robot is this? can you post a photo? also please zoom in at the PP
Hello.
Please some photo my robot NX100-SRB30f. Robot manipulator is 7 axis and one Extenal Axis.
Thanks sir. -
More photo
The keystrokes depend on if it has stamping or welding software. I'm assuming arc welding since a picture looks like Dimple in the background.
To change the language of the Universal Pendant perform the following:
Arc Welding Software- In Teach, press and hold the Enable key (Green key on left below screen) + Service (upper right of the pendant screen). Cursor to the #4 (switch language). Press Enter.
Stamping Software 1.6 and lower- Press and hold the Enable Key + the Interface key (very bottom of pendant 4th key from left).
Stamping Software 3.0 and higher- Press and hold the Enable Key + the Help key (One key below and one key to the right of the orange key with green on top about in the center of the pendant).
If none of these work, please hollar.
Hello sir
My robot may be welding software. When i go to the #4 (switch language). Press Enter. I is not allowed. It is silen.
Thanks sir! -
I don't understand Japanese. Press and hold ENABLE then touch SERVICE (upper right of screen). Take a picture of this screen. I can compare to the controllers I have and might be able to figure it out. I know I could with the pendant just by knowing key combinations.
Hello sir
This is screen. I choise #4 but it not work.
Please help me.
Thanks you. -
More photo base screen sir.
Looking at your screens, it is arc welding software. Pressing ENTER on Switch Language should have worked. The controller may not be set up with English as a second language. To verify: Press and hold ENABLE. Touch in the upper right of the screen. Picture 083553 is the first screen. Picture 083604 is the second screen. 083614 is the third screen.
Do not follow the numbers. Look at the Japanese characters. My numbers are different than yours. After you cursor to the icon press ENTER. The end result should put you in a version screen that will have the software version at the top. It will have NTX.XX-XX(JP/US)-XX. The X's are numbers. What I am looking for is if in the parens it says US.
Dear sir.
May be my robot just Japan language. Kaka
Please see in attachment file -
申し訳ありませんが、より良い日本を学びます。
Sorry, better learn Japanese.
Dear sir.
Thanks you anyway. I will find english software. By the way I like your watchword about wine...
Big Thank sir!
