hello every body
i have a abb irb140 S4C+ robot that the system go to hell
it has not any CD or etc
now i want to install system with robinstall but need tho robkey.kxt file for this robot.
does anybody has it ?
plaese HELP
amir65esf -
August 22, 2016 at 9:10 AM -
It
isshould be possible to retrieve the key from a backup - if you have one... -
Itisshould be possible to retrieve the key from a backup - if you have one...So i don't have one
Have you tried contacting local ABB support with robot serial number?
please some one give me a irb140 robot key
It's not as simple as copying the key file from one machine to another. The key is based on what options are in the machine - if you add a package, you need to get another key file. It's also a form of copy protection.
Have you tried contacting local ABB support with robot serial number?1-800-HELP-365 (1-800-435-7365) stateside.
Hi amir65esf,
Iowan is correct, you should contact your local ABB support. Which controller you're using?
Hi amir65esf,Iowan is correct, you should contact your local ABB support. Which controller you're using?
I have S4C+ controller -
Okay, What Kind of Options you're looking for??? Send me PM
I know I am late to this dance, but, I had a similar issue not too long ago. ABB will help to the extent it can with recreating the original job. It isn't cheap. If your system will be in use more than year, it will pay to get the back-ups recreated to avoid future issues.
I know I am late to this dance, but, I had a similar issue not too long ago. ABB will help to the extent it can with recreating the original job. It isn't cheap. If your system will be in use more than year, it will pay to get the back-ups recreated to avoid future issues.Is ABB supporting S4C+
Not for much longer?
I don't think they'll tell you to go pounce just because you have an S4C+, they will usually try and help as much as they can.
With S4C+ the main issue will be spare parts which is why they have an incentive for people who want to upgrade their controllers to IRC5.ABB won't recreate any backups, they can however (depending on how old the system is) either:
A) Download the last known key for your system from their database (this can be done by the local organization).
B) Re-generate the keys based on the last known information (this usually have to be done by the mothership).
