i get a error 40223 task main: fatal runtine. when we scan the new program it doesnt delete the previous one any help
ABB s4c+ teach pendant
travieso550 -
July 21, 2016 at 3:25 PM -
Doesn't really sound like a teach pendant problem.
I've had machines that loaded two copies of the same program. I had to delete both copies and reload the version I Wanted. -
is not the teach pendant is the program i think something wrong with the routine
Did the error pop up after loading a program/module?
Was the program created via pendant or offline (then loaded in)? The error could be as simple as a missing semicolon.
Documentation on error 40223 suggests there should be another error that is more specific - usually mentions the line number containing the fault. -
yes the message pop up after loading a new program. i think they were created offline. what do yu mean with missing semicolon?
you have a problem in your program.
dont worry about teach pendant -
yes the message pop up after loading a new program. i think they were created offline. what do yu mean with missing semicolon?Most commands require a semicolon at the end of the line. It isn't usually visible from the teach pendant, but you can see them if you look at them with a program like Wordpad. There are some other (better?) programs that do syntax-checking. I use Wordpad, but have spent some frustrating sessions trying to locate typo's.
