Has anyone used Laser optical sensor on ABB when welding a seam?The sensor should correct the welding path when there is a deviation between the real seam path and the one you teached. Somehow,the gun shakes on Z direction when tracking.Why does it happen on ABB ,this phenomenon never happen on KUKA and FANUC.
Shake on z direction when ABB use optical tracking
kulegege -
July 1, 2016 at 10:44 AM -
I haven't done any seam welding, but I've seen some "ripple" (or "cogging") on an older laser cutter.
What does your system look like ? S4 / IRC 5 ?
Which laser camera do you have ? Servo Robot / Meta ?
What's your track data values ?
Odds are your gain is fairly high but without additional information it's hard to guess....
Thanks for reply!
My system is IRC5, the laser camera nether of those ,is made by my company .
I have worked on other projects these days,sorry for waiting.
There is the sensor log copied from abb. -
Which RW, 5.X or 6.X
Is it Binzel ? Or is it under development ?
Looking through the tracklog your sensor reading in Z is quite "lively" which leaves you with two options....
A) Try and redefine your joint in the camera software to stabilize Z, if the joint is a machined surface there might be issues with reflections.
B) Increase the filter / dampener in your track data (this will dampen / make it slower) the overall correction so it might make it too "numb" for what you're trying to do.
filter (path correction filter)
Data type: num
The filter component defines the time constant of a low pass filter applied to path
corrections. The component may be set to values from 1 to 10 where 1 gives the
fastest response to path errors detected by the sensor.
