Modbus TCP
  • TSGIR
  • June 14, 2016 at 10:20 AM
  • TSGIR
    81
    715
    Hi
    I want to connect with Omron PLC via Modbus TCP communication. i instal moto modbus in controller. now, i don't know how can i test and write and read data between them. do you have example?
  • TSGIR
    81
    715
    • June 22, 2016 at 10:45 AM
    can you write a sample for read/write?
  • cal0ger0
    25
    • October 18, 2016 at 11:56 PM
    On robot side you don't need anything else, only the manual of MotoModbus to understand which address you have to read from PLC and .....enjoy ModbusTCP :top:
  • TSGIR
    81
    715
    • October 20, 2016 at 6:46 PM
    Do you have manual and example? Can you send me?
    asgary.aliasghar@gmail.com
  • cal0ger0
    25
    • October 21, 2016 at 5:30 PM
    You don't need examples because MotoModbus is a server (you don't need any job).
    The manual is on MotoModbus CD or ask to Yaskawa hotline of your country.
  • Mr.Zed
    7
    • October 31, 2016 at 6:08 AM
    Quote from Acid
    how to implement data transmission over ModBus? I can not understand how I see me in the controller necessary data (e.g. current power) to bring to the SCADA
  • cal0ger0
    25
    • November 2, 2016 at 1:23 PM
    Modbus is like Profibus and other fieldbus, where you can read IN and OUT of the robot. If you modify ladder, you can send to the robot, command like e.g. Servo ON, or read status like e.g. Errors.
    Really Modbus is better then other fieldbus, because you can access directly to the variaible (B, I, D).
  • Mr.Zed
    7
    • November 8, 2016 at 8:12 AM
    Quote from Acid
    Please tell me how to pass for ModBus error codes?
    I can pass values of voltage and current. For this, I am writing a program in the ladder structure (USER LADDER).
    how to write a program in USER LADDER to transmit an error code?
    Thanks!
  • cal0ger0
    25
    • November 11, 2016 at 11:11 PM
    Quote from Mr.Zed
    Thanks!
    • Register M640 Alarm Code (Binary/BCD)
    If an alarm occurs in the system, the corresponding alarm code is output. If there are two
    or more alarms, the code of the first occurring alarm is output. To switch binary and BCD
    data type, use the parameter (S2C315). Factory setting is binary.
    • Register M641, 642 Alarm Data (Binary/BCD)
    This data is detailed information added to the alarm code
    You have to copy (by ladder) this registers to some variables or network output
Users Viewing This Thread
  • 1 Guest
