hi
I want install win xp for kuka KRC2, but don't load boot from windows CD ,
I need guidance for install windows , my CD haven't setup
how can do install windows ?
please help me .
metod for install winxp for kuka KRC2
km427 -
May 31, 2016 at 4:12 AM -
configurate the bios to first boot on cd , then just follow the instructioins
the cd winxp its booteable
You have to below steps to make the computer boot from CD:
1). Connect keyboard, monitor and mouse to your controller. Insert the CD into the drive and make sure that the drive is reading it.
2). Restart your controller PC and press F10 or F12 (don't remember on top of my head). You should see a message which display how can you go into BOOT menu.
3). Once you are in Windows BIOS, you should see a complete blue screen with different tabs and details.
4). Go to tab named BOOT. There you have to select First BOOT device as CD Drive.
5). You have to save and exit the settings.
6). Windows will now boot from CD and the setup of Windows 98 should start.
7). Once the complete Windows installation is done then follow above steps again to change the First BOOT device back to Harddisk. It will allow your computer back to normal starting operation.
8). Then you can go ahead with other installations of KSS and tech packages if you want.Good Luck
thank you ,
I do , configurate the bios to first boot on cd but don't read boot on CD . I need download link for download winxp
can you help me ?
I thik windows failed . -
Your Windows CD or CD Drive on controller PC may be non functional. Try to use the CD on some other computer to see if that computer boots from CD. If this would be the case then you may need to use an external CD drive or make a bootable USB.
Look for other options.
I do all work , but unknown boot from cd ,
I install win 95 after install computer don't start normally , system start safe mode message:window protection error you need restart your computer
then after restart , safe mode now I must install winxp
I need download link windows xp , please help me
my windows haven't setup in windows xp CD so Cd is failed . -
First this is not just WIN95 or WINXP.
KRC2 works with one or the other not both.
Older models where running with WIN95.
But you cannot grab any WIN95 and install it.
Its a KUKA custom WIN95 or KUKA custom WINXP Embedded.
Whatever was supplied with the robot will work with it.
You cannot grab any windows XP cd(or WIN95) and install it on KRC2.WIN95 needs a startup floppy - there is copy of the boot floppy on KUKA CD with software.
WINXPE installs from CD (boot order needs to be changed in BIOS) -
If your KRC2 was supplied with WIN95 you cannot update to WinXPe.
IF you already have WinXPe there is nothint to update. -
WINXPE installs from CD (boot order needs to be changed in BIOS)I'm having same troubles with my krc1, does it has a copy too?
