hello
our friend
I want install win95 to kuka ( KRC2 , Kuka 360) but after install don't start normally , window95 start safe mode
Can i install win 95 for kuka Krc2 360
km427 -
May 29, 2016 at 7:17 PM -
I had a similar problem , but with Krc1 , just change the hdd, and was possible install Windows 95 and kss
Maybe it's a problem of hardware, also try to install winxpe and kss 4.x
I've not trying winxp +kss 4.c maybe works it
Sent from my iPhone using Tapatalk
thank you
I idea don't COMPATIBLE with hardware , but How to do install WinXP
I need help , The first be installed win XP but it problem in system and i decide change window to win 95 but don't answer
what do i do ? -
Sorry friend, I don't understand you .
I see that you problem can be solved restoring a past backup.
If you install win95 before to install kss, first install "smsetup.exe" located on folder tools /internat
Restart...
Install kss
If you install xpe
Just install kss
Also you can install language, and security's before kss but it's not completely necessary, just xpe +kss
BR
Thnk you
hard capacity is important for install win95 ?
how many hard capacity is necessary ?
hard capacity is 80G.
fdisk is necessary ?
Win 95 run over fat16 (fat)
Please , read documents about properties of fat16 (fat) , fat 32 ,ntfsThe maximum Mb on fat are 2048 Mb (2.0gb)
You need 2 partition c,d
Winxpe create automatically 2 partitions but on ntfsSent from my iPhone using Tapatalk
I change hard , and fdisk then create partition after install window 95
but problem is nutriment
but win 95 agreeable with KRC2 .
I don't know , what do I do .
pleas help
