Is there a way to turn off/on BGLogic in a TP program?
Stopping BG Logic
Jct171 -
May 25, 2016 at 7:49 PM -
This would be more of a job for conditions, not BG
but if in your bg program there was a line like
if r[ x ]=1 jump label 1
here is stuff you want turned off
LBL[1]
and then in your program you toggle that register that would do it for you
I did something like that with a flag however when I ran It I got an OS 144 error in roboguide which I did not want to have on the robot. Would a register behave differently?
it should work fine with either.
if you are still having problems post the code
BG logic does not support labels and jumps.Actually it dose, however you can only jump down in the program, not up.
You are right. It was my mistake.
