I need to compare the position valus from two backups with a same robot from kuka
Can we compare the two different backups from kuka with same robot?
Is there is any software that compares the position value from two different backups with same robot in kuka?
Kuka Backup
amolghule7 -
May 4, 2016 at 7:59 AM -
We use an MDT software product called 'Autosave'. It is an file backup software that archives the files anytime there is a change detected. It has a compare feature that will analyze the files you choose and create a report of all of the differences including Position values. If thats not an option maybe look at the .dat files for the programs you want to compare and you can see the positional data for all of your points.
Sent from my SM-G900P using Tapatalk
Hi
I usually use kdiff3 (http://kdiff3.sourceforge.net/). It is free and allows comparing pretty much everything on file basis after extracting the archives.
Fubini
