Hi Everyone,
Anybody have any idea about Tera Term? Because One of my controller(ABB s4cplus Auto M2000A with IRB 6650) is keep on booting, So, I checked with null modem cable connected to COM1 on CPU unit and when I'm Ping on command prompt it saying "IP address: Destination Unreachable" and when I try with Lan pinging in Command Prompt its connecting but when I open Tera Term it showing Connection Refused. If anyone know what is TCP/Ip setting for Tera Term. Please let me know, Thank You
Tera Term
sandeep.lerio -
April 26, 2016 at 6:34 AM -
If you reboot the robot you can see where it is waiting for in hyperterminal, or teraterm.
You are doing it wrong. If you are using console port, there's no ip address to connect. It's a serial port, use a program like hyperterminal and configure the COM port. If I remember correctly the configuration is:
Baud Rate: 9600
Data Bits: 8
Parity: None
Stop Bits: 1
Flow Control: None -
If you are using windows 7 or up, you can use Putty terminal to connect to the console port of the controller. It's free
Tried Everything but nothing worked out. It is not showing anything It keeps on booting. I removed the flash disk and checked with other controller flash disks are working fine. Any other solution and can anyone share some screen shots How to solve it? Thank you
Here's a procedure I got from ABB.
Hi Iowan,
Thanks for reply. I will update you the details about it very soon. And I already check the flash disk i removed from the controller and connected to other and it's working fine. No issue with Flash disk. Maybe I guess null modem cable is wrong. I will update you later about it. Thanks once again
