I am using a KRC4
I am running into some major errors as I try to add modules into the KUKA Extension Bus into WorkVisual.
I currently have this setup plugged into the x65 on the front of the controller: KRC4 -> EK1100-> EL2008 (4 in a row) -> EL1008.
I have the files from Beckhoff already loaded into WorkVisual and can access them through the DTM catalog management.
Whenever I right click on the Kuka Extension Bus and attempt to add the Ek1100 I get an error that forces WorkVisual to shut down.
If I try to scan topology instead, it comes up with the error "Error in DTM Kuka Extension Bus (SYS-x44): The EtherCAT masterstack reported the following error: 981100B "Error: Invalid parameter"
Any help or suggestion that anyone can provide would be much appreciated.
Thank you
