  3. Cobot Help and Discussion Center
  4. KUKA LBR IIWA
Background Tasks monitor What Robot Application is running in KUKA LBR iiwa R820
  • vinhnguyen.ac
  • April 5, 2016 at 5:47 PM
  • vinhnguyen.ac
    17
    In KUKA LBR iiwa, the controller can run different background tasks parallel with robot applications.
    I would like to run a background task to monitor what robot application is running, and when it is stopped.
    Does anyone have an idea how to do that?
    Thank you.
    Vinh
  • KUAJARLOS
    28
    • September 7, 2016 at 7:08 PM
    The task must be programmed in a class background task. Attached example where I want to control the force of the robot in Z.
    What I need to know is how to start this background task?
    thanks
    Files
    background task.doc 30.72 kB – 85 Downloads
  • kiiwa
    369
    • September 9, 2016 at 9:44 PM
    Quote from vinhnguyen.ac
    Thank you.
    Vinh
    I never tried it. Mu instinct tells me to see if there's a Java program that can check on the JVM. Just a wild guess.
  • kiiwa
    369
    • September 9, 2016 at 9:49 PM
    Quote from KUAJARLOS
    thanks
    You cannot control/move or display on the SmartPad from a background task.
    This instruction :
    initializeCyclic(0, 500, TimeUnit.MILLISECONDS, CycleBehavior.BestEffort);
    Means that your background task starts right with robot startUp ( 0 ms delay) and the program runs each 500ms (i.e. 500ms is the time between two calls of runCyclic() )
    What are you exactly planning to do?
  • KUAJARLOS
    28
    • September 12, 2016 at 9:28 PM
    Hello
    I want to do is display the value of the force made by the robot in Z while making a path.
    ForceSensorData data =lbr.getExternalForceTorque(lbr.getFlange());
    Vector force1=data.getForce();
    double forceInZ=force1.getZ();
    getLogger().info("Force=" + forceInZ);
    but I do not visualize "Force =" at any time. Can it be because the time to be lower for example 10ms?
    Example:
    initializeCyclic(0, 10, TimeUnit.MILLISECONDS,
  • kiiwa
    369
    • September 14, 2016 at 12:54 PM
    I see. You want constant display on the smartPad at the same time as the robot moves.
    Try using a Thread for that, I'm not sure if it can access the SmartPad , though. I'll try it in the coming days if I'll have time.
  • KUAJARLOS
    28
    • September 14, 2016 at 6:52 PM
    Thank you very much, it would be very great help
  • weifan
    8
    • October 25, 2017 at 3:00 PM
    Hi, I am also working on the background task too, can you help me this post?
    https://www.robot-forum.com/robotforum/kuk…ackground-task/
    I really appreciate if you can help me. Thank you very much!!!
