I would like to know how I can verify that the deployed project on a KR C4 controller corresponds to a specific WorkVisual project. Is there some agreed procedure?
Thanks!
Daniel
Thanks!
Daniel
you can use WoV option to compare projects
I make it a habit to change the name of the WoV project after making changes before re-deploying. This makes it very easy to see which project is running. By tapping the WoV symbol on the left side of the SmartPad, I can verify which version of the project is running.
yep, that is a good practice....
you can always remove unwanted projects but it is a good idea to have fallback/alternate projects
I deploy project only up to the case of making changes in Hardware config. After, I finish the changes in HW, I do not wish to deploy as it is very annoying process. After finishing HW, if I need to add new program or changes in programs, I just make the changes on my computer and then copy that program into the KUKA directories. This it is faster and safer.
I wish KUKA would develop a feature of partial deployments.
