I've tried the Startload-Waitload functions from FLP1 (USB conversion), but it won't let me change channels to load the next program.
Is there a way to 'release' FLP1 so I can change channels?
Current program loop (basically):
-Startload Prog1
-Waitload Prog1
-channel+
-Startload Prog2
-Run Prog1
-Waitload Prog2
-Channnel(-)
-Unload Prog1
-Channel+
But the USB drive won't let me change channels, as if the drive is in use while the program is loaded.
I'm out of ideas for now, I'd appreciate any help I can get.
old stuff ______________________________________________________________________________________________________________
Using Filezilla Server on PC:
Error Message:
"Mounting directory 'C:\Robot1' on the computer '192.168.125.81' failed", so in FileManager, the unit "pc:" is viewed as Empty or Bad Disk.
Probably because the S4C is too old, I couldn't get it to work even with the earliest version of FileZilla on Windows XP.
PC LAN Settings:
IP: 192.168.125.81
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.125.80
Communication parameters on the S4C (more important than the S4C+, since I can't transfer files at all on S4C)
Application Protocol:
Type: FTP
Transfer Protocol: TCPIP1
Server Address: 192.168.125.81
Trusted: Yes
Local Path: pc:
Server Path: C:\Robot2
Username: Robot1
Password: abb
Show on TPU: Yes
Transmission Protocol
Type: TCP/IP
PhyChannel: LAN
Local Address: 192.168.125.83
