If I have two KRC2 robots, both with CP1616 profinet card, will it be possible to have direct communication between the two robots (while each robot has its own IO)?
Kuka KRC 2 , CP1616
Plc_User -
February 8, 2016 at 9:37 PM -
It should be possible. One robot would have to be the bus master, and the other the bus slave.
Yes it's possible. In the simatic side configure to one robot Profinet Controller, one robot profinet IO device.
The problem is, that both robots need their own IO on profinet (digital IO) next to the communication between the controllers.
Can the CP1616 be controller and device? -
Yes CP1616 supported Profinet IO controller or Profinet IO device. Modes selected from software (KSS or Simatic Manager)
Details:
https://cache.industry.siemens.com/dl/files/620/6…4-CP1616_76.pdf
One robot could be a Master to the other robot, and to its own slave devices (grippers, weld guns, etc).
The other robot would be a Slave to the Master robot, but still be a Master to its own local slave devices.
However, for the KRC4 implementation of ProfiNet, multi-master is NOT allowed. That is, a Slave can only be slave to one Master -- no sharing. So if you have a Cell PLC that needs to be a Master to both robots, then direct robot-to-robot ProfiNet is not an option. You would have to set up pass-through for that I/O on the PLC.
