How to add more REFPOS checks? I attached a photo
REFPOS MENU
Ereghi -
December 15, 2015 at 2:41 PM -
How to add more REFPOS checks? I attached a photoIt's in the variable listing somehwere.
Check $REFPOSMAXNO.
Check $REFPOSMAXNO.Also, if you want more than 10 enabled at once, you will have to modify $REFPOSMASK[1].$MAXREFPOSEN. Of course this system variable isn't documented, so I wouldn't go nuts with it. Increasing it too high would likely decrease robot performance.
thank you for the information found it changed it
Nation,
I thought your post had resolved my problem but after accessing $REFPOSMASK[1] I couldn't locate $MAXREFPOSEN only REFPSMSK_T. Any suggestions?
Found this going to give it a try.
The variable you need to access in not in the variables menu, AT LEAST NOT ON VERSION 7.70 R-30iA
Here is a program that will change it to 20,
/PROG REFPOSSET
/ATTR
/APPL
/MN
1: $REFPOSMASK[1].$MAXREFPOSEN=(20) ;
/POS
/END -
Nope that did work either.
What rev of robot controller are you running?
Ver 8.30P/20 It needed a cold start. Now working thanks all who provided info!!!
