I was wandering if anyone could tell me if there is a possible way to disable T2 to not be used only T1 for safety purposes.
Can I only disable T2 function on Fanuc R30iA
Beejaybarnes -
November 25, 2015 at 4:46 PM -
I'll try to remember to check a robot Monday, but it would seem that the switch could either be modified to block the T2 position, or wired to disable the T2 option.
You can change the system variable $SCR_T --> $T2_Lock_Enb (number 132) You have to change it in controlled start I believe.
Great that is what i was looking for. Big Thank you works great! Really appreciate it!
