I am looking for CRMA15 and CRMA16 connector connection diagram. I need to find out signal voltage of the inputs and outputs when they are "ON". I am working on Model R30iB controller.
Thanks,
Thanks,
I am assuming you are working on an LR-Mate where you are trying to uses the 20 inputs and 20 outputs? These are all 24vdc signals that are positive switching.
I'm sorry. I just start working in Fanuc Indonesia. I just want to know that CRMA 15 cable is female or male connector? Thank you
pls fins the attachment
"R-30iB Mate main board (CRMA15, CRMA16)
The R-30iB Mate controller is equipped with peripheral device control interfaces, which have 28 input
points and 24 output points in total. By default, the signals of the peripheral device control interfaces are
assigned to DI[101-120], DO[101-120], DI[81-88], and DO[81-84]. In the LR Handling Tool, the signals
of R-30iB Mate I/O main board are assigned to peripheral I/O by standard I/O assignment, because UOP
auto assignment is set to "Simple(CRMA16)"
this is what i found in the operators manual, where it is stated that there are 28 inputs and 24 outputs ?
