getting a hardware error 37057. SMBUS unit at address 38 is not responding. then says SMBUS unit lost. What or where is address 38? What are sure signs that your SMB needs replacing? any tips fellow ABB'ers would be greatful? thanks
smbus irb1400 m2000
TillageBots -
November 2, 2015 at 9:29 PM -
Here is a similar problem.
Do any of the suggestions help?
I had a similar issue that was resolved by simply unplugging and reconnecting the cables (power off, of course). -
As usuall I did more things at once than I should have. So trouble shooting is not precise. I disconnected and connected cables outside cabinet and made sure all connections were good at the 509 board. I think the best attempt was cold starting and then restoring a backup from before the trouble started. That took care of it going into system failure state. Power supply to SMBUS is yet to be determined.
