Hello all
I have a question about programming.
How to create loops in the program?
Control rooms krc2
loop
widelec -
October 18, 2015 at 9:42 PM -
check 'programming manual for system integrators'. if there is one manual you need to have, make it that one.
there are several loops....
Code; counting loop requires INT variable which must be declared before use FOR N=1 to 10 ; do something ENDFOR
where condition is any boolean expression or variable.
note, to add code like this you must login as expert and use Open instead of Select...
Thank you very much for your answer panic mode
