Hello all,
I am using an analog input value that I load into a register to do some calculations with. I'm having an issue where the first 32,767 counts give me a positive number when i load it into a register but starting at AI[]=32768 the value in the register is -32768 and as the analog value increases further the value loaded into the register counts toward zero from -32768. I'm guessing this has something to do with the register being set as a signed integer but have no clue how to fix it. using r-30ib handling tool. Is there a way to make it where these negative values don't show up?
Any input is much appreciated! thanks!
half Analog input range is negative when loaded into register to do calculation
robot take over -
September 16, 2015 at 6:37 PM -
This is kind of a hack, but try adding 0.1 during the register assignment. This should cast it to a float, which can take much larger numbers.
Thanks for the suggestion nation, I gave it a try and I still get the same issue. I also tried to divide the analog value by 100 to make it smaller which failed as well.
It works on my end too! Thats interesting that mixed logic handles it correctly.
Thanks for taking the time to help me out Nation. I really appreciate it. -
Somewhat off topic, but what kind of analog input card are you using?
I recently tried to order the 16 bit model a i/o card and was told that they don't offer one, even though it's in their manuals with a part number.
This leaves you with the 12 bit card, which limits the resolution to +-2000. When you have a nice analog sensor, it kinda sucks... -
I use a Numatics G3-3 valve manifold that has input modules. I map it over ethernet IP scanner connection.
How are you transmitting an analog signal over a digital protocol? Are you using group i/o?
