how to delete unused targets from irc5 controllers??
deleting unused target
Tushar_Patil -
September 5, 2015 at 6:57 PM -
Are you wanting to search for all unused targets and delete them at once? Use RobotStudio to connect, go to RAPID tab, open the find/replace dropdown menu, and "Remove Unused Data in Module."
One note of warning though; This isn't smart enough to look at your entire system and see that another module might be accessing the data in the module you're deleting from, so you may cause Rapid Reference errors.
You can also just "find unused data in Task", which does check for cross-referenced data, but it will not delete it for you.
OK THANKS
