I having robot arc mate 120i with Rj2 (Europe) controller.
I need position register for my programming purpose. Presently on register option is there. so how to add position register into it.
Thanks in advance.
Thanks in advance.
Press data then F1 and then select position registers
I had done this ,but it is showing only register & not position register???
You may have quick menus enabled. Press FCTN then 0 for the next page then 1 toggle quick menu/full menu
To see Position Registers
Press:
1. Data
2. F1 (Type)
3. Down arrow one time to highlight Position Register.
4. Enter.
5. Then don't change anything because if you don't know how to get to that menu, you probably will end up messing something up.
,good luck
Position Registers are still shown in quick menu.
Not all robots have positionregisters, and it will load a program with any, but it won't execute the line.
I had three of them, and I asked the same question, but got no answers...
One of them got fixed by a controlled start, where you can fill in the number of positionregisters. (which was zero)
That did not help with the other two, and I ended up reprogramming the boards. (with handling-tool)
All of them had arc-tool or spot-tool, maybe that has something to do with it ?
The robot with arc-tool was the one fixed by a controlled start, so maybe yours can too.
Thanks All.
If I'm not wrong arc mate robot don't have position register??
Or have to enable them by going into the quick menu??
