hi everyone,
how can i make the robot move continously when there is a subprogram change in the code? is it possible somehow?
thank you!
hi everyone,
thank you!
do not use the INI Fold in the beginning of your subprogram. It contains advance run stopping instructions and hence no approximation move is possible.
Fubini
I sometimes had issues doing that, if I needed to directly select and run the sub-program for testing purposes. For situations like that, I generally included the INI fold, but put it inside a IF-BCO check, prefaced with a CONTINUE. That did the trick nicely.
