I have a customer that has a couple of S4C controllers (robotware 3.2) in his plant.
Sometimes they get errors on the controller that are 'not logic' compared to the actual situation.
ABB already told me that reinstalling a backup of the project sometimes solves these sporadic errors.
I was thinking may a complete reinstall would be even better.
I suppose for these kind of systems I cannot use robinstall, but I need the installation discs.
If the customer does not have the original installation disks, I suppose I can get these from ABB?
If the customer gives me disks, how can I be sure it are correct disks before I start the operation?
Reinstall system
Plc_User -
August 8, 2015 at 10:55 PM -
Been awhile but. If you have a backup you can try find the keystring. If you can find a key you can make new boot disks using robinstall. It's all about finding the key if the software was able to take the keystring with the backup. Hope this is helpful. Good luck.
For BaseWare 3.2 software, there should be a system pack of approximately 10 floppy disks. To be able to load the software, you must have the key disk specific to your robot. The key disk will load the encoded keystring that determines what gets loaded from the disk pack. From there, just follow the prompts.
